SailNet Community - View Single Post - Reusing a prop
Thread: Reusing a prop
post #8 of Old 05-06-2013
dacap06
Send a message via Yahoo to dacap06
Re: Reusing a prop
Originally Posted by nestorph View Post
Just an FYI. I called Indigo and the gentleman said that the I-30 has a reducing gear for the diesel engine and it wouldn't turn the prop fast enough. He said he had worked with another customer who wanted to do the same a while back and even changed the prop pitch, but it didn't help. In the spirit of sour grapes, it was going to be too hard to remove the old prop anyway... ;-)
Good point! Whenever you provide the prop's setup info to determine pitch, you must also provide the transmission's gear ratio. Islander used several different ones with the Yanmar, so you can't just assume the most common one. You can find it on the plate on transmission case, which is readable from the access port in the quarter berth of the I30B.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
