SailNet Community - View Single Post - changing helm style
post #15 of Old 05-07-2013
chef2sail
chef2sail's Avatar
Re: changing helm style
I never sit directly behind the wheel. I usually sit on the high side behind the wheel. I took out the bench part directly behind the wheel to give me more room when I stand behind the wheel or to move from one high side to the other when tacking.
Dave
In case all those naysayers haven't talked you out of it by now, here's Edson's specific instructions how to do it on your boat:
http://www.edsonmarine.com/support/w...pdfs/S-752.pdf
I have a Catalina 250 with a wheel, and everything said here is true. It is tough to get around the wheel on such a small boat. As one who has chartered up to 38' boats, I can tell you the wheel is always tough to get around on ANY size boat.
There's always a religious debate over which gives you a "bigger cockpit." If you're sitting at the dock (or at anchor) having drinks, the tiller is a bigger cockpit because you can swing it up. (But a removable wheel would solve much of that problem.) But while you're sailing, I contend that the wheel gives you a bigger cockpit because pilot sits behind the wheel, and two people can sit to either side of the wheel, which is space that would need to be left clear with a tiller.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
