SailNet Community - View Single Post - Low buck projects- Let's see 'em!
post #650 of Old 05-07-2013
jimgo
Asleep at the wheel
jimgo's Avatar
Re: Low buck projects- Let's see 'em!
Here are the pics. I started with the fully assembled lamp and then took pieces off one by one so you can see how the glass chimney and globe are retained.
I'm sorry, those can't be converted. You can just send them to me and I'll dispose of them for you.
No?
Darn, that never seems to work.
It looks to me like those are the right diameter to use the Christmas-style lights (the fake candles that you put in your window). You could scavange the innards from one of those lights and install it in the lamp, bringing the cord down into the base. You'll have to put a hole in the lamp somewhere to allow the cord to exit, which will ruin the base so you won't be able to put in any oil, but that seems consistent with your plans anyway.
What I'd consider, though, is running those off of batteries. If the top comes off, you should be able to use the oil bowl/base as a holder for the batteries, and simply run the wire up the wick tube to the scavenged lamp base.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
