SailNet Community - View Single Post - Is this gelcoat/fiberglass recoverable?
post #6 of Old 05-07-2013
overbored
overbored's Avatar
Re: Is this gelcoat/fiberglass recoverable?
At $200 and if it is all there and usable. clean it up with soft scrub and go sailing. if it turns out to be the boat for you, then it might be worth a coat of paint. the deck gets the most sun and wear but also look at the bottom of the keel they can get worn thin to the point of leaking from dragging through the sand. check out Cat sailor for a lot of info and boats for sale Catsailor.com Classified Ads
"GOLD RUSH" PRINDLE 16
overbored is offline
