SailNet Community - View Single Post - Soft Sole Replacement
post #23 of Old 05-08-2013
davidpm
davidpm's Avatar
Re: Soft Sole Replacement
Originally Posted by Chartreuse View Post
WOW. This is great!...All that sanding-all that sanding that doesnt need to be sanded.
Is one side finished and the other rough for bonding? Thanks for the site!
Bonding shoudn't be an issue.
Just scuff sand the underside with 80 grit and bed in thickened epoxy.
Done carefully you will have a smooth solid surface. The only fairing will be at joints and edges. Way easier than dealing with a large flat surface.
davidpm is offline
