SailNet Community - View Single Post - Galley water pump stopped
post #7 of Old 05-09-2013
lajimo
lajimo's Avatar
Very similar thing happened to me recently and it turned out to be gunk in the bottom of the tank that shifted around and clogged up the tank outlet. Quick check is to disconnect your water line at the tank outlet -if it doesn't flow freely then that's your issue. I reversed my wet vac and blew into the line and it freed right up.
lajimo is offline
