SailNet Community - View Single Post - Any tips for removing corroded bolts at rudder?
post #2 of Old 05-09-2013
CalebD
Tartan 27' owner
CalebD's Avatar
Re: Any tips for removing corroded bolts at rudder?
No need to use wd 40 for this. There is a much better product called PB Blaster that will work better. I have had good luck spraying old, nasty looking bolts with this stuff. Sometimes I have to let it work for several days with several applications. So far I haven't been disappointed with pb blaster.
There are other penetrating oil products as well: Kroil, SeaFoam etc.
If you can't find any of these then use ATF (automatic transmission fluid) mixed with a little acetone.
I'm not really picturing what you are describing under the transom seat. A picture might help a lot.
Good luck.
Everybody has one:
CalebD is offline
