SailNet Community - View Single Post - Any tips for removing corroded bolts at rudder?
post #4 of Old 05-09-2013
mike dryver
Re: Any tips for removing corroded bolts at rudder?
PB blaster and heat!!!! heat the bolts one at a time heat 1 not to the point of turning red, just hot, spray the blaster (note it will smoke and the fumes will irritate your lungs, throat and nose) so try not to inhale when you spray, then turn away> do this to each bolt several times, then soak with PB over night. come back following day and do it again, if you have to.
mike dryver is offline
