SailNet Community - View Single Post - Dry bilges
Thread: Dry bilges
post #9 of Old 05-10-2013
SlowButSteady
Senior Slacker
SlowButSteady's Avatar
Re: Dry bilges
I dry sailed my old boat (i.e., "moored" it on a trailer). There was an approximately 5/8" drain hole in almost the lowest part of the bilge. To keep the last little bit of rainwater from just sitting in the bilge I took a length of cotton twine and laid it so it ran through the wet area of the bilge and then out the drain hole, with about a foot or so dangling under the boat. When it rained the the water would overflow out the drain hole and the twine would get saturated. It would then act as a siphon and draw the rest of the water out.
If you have a fairly deep bit of bilge near to your problem area try some version of the above string trick and see how it works. If it doesn't work you're only out a penny's worth of string an five or ten minutes of your time.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
