SailNet Community - View Single Post - Dry bilges
Thread: Dry bilges
post #11 of Old 05-10-2013 Thread Starter
Minnewaska
Re: Dry bilges
Originally Posted by SlowButSteady View Post
I dry sailed my old boat (i.e., "moored" it on a trailer). There was an approximately 5/8" drain hole in almost the lowest part of the bilge. To keep the last little bit of rainwater from just sitting in the bilge I took a length of cotton twine and laid it so it ran through the wet area of the bilge and then out the drain hole, with about a foot or so dangling under the boat. When it rained the the water would overflow out the drain hole and the twine would get saturated. It would then act as a siphon and draw the rest of the water out.
If you have a fairly deep bit of bilge near to your problem area try some version of the above string trick and see how it works. If it doesn't work you're only out a penny's worth of string an five or ten minutes of your time.
Neat trick, may try that over the winter too. Unfortunately, the only way to route the string now would be back through the place where the water enters.
Jeanneau 54DS
Minnewaska is offline
