SailNet Community - View Single Post - Whats up with my keel?
post #9 of Old 05-10-2013 Thread Starter
Chartreuse
Chartreuse's Avatar
Re: Whats up with my keel?
Originally Posted by CalebD View Post
This from the Grampian Owners Website link above:
"McGruer's design mandate had been for a comfortable family sailer, with six-foot headroom in the interior, and the berths for four (five if you squeeze two into the pull-out settee). She was to be strong and seaworthy, and trailerable - hence the swing-keel version. (The swing-keel has a draft of 3ft with the keel up, 6ft 6in with the keel down; fixed keel draft is 4ft 3in.)"
So, if you can figure out the approximate draft of your boat you should be able to figure out if it ever had a center board. If the draft is around 3 feet then it should have a center board; if the draft is around 4'3" then it is the fixed keel version.
Should be fairly easy to figure out.
I can tell from pictures that mine is not a 4'3" fin keel...But what about the possibility that it is the elusive shoal draft, with no CB?
The draft depth should be a good tell, and I'd say off hand that it looks closer to 3', but my uncertainty derives from the fact that I dont see any gear, cable or mechanism for a CB in the cockpit or cabin.
Of course, that too may have just been done away with. Thanks for the input Caleb!
Chartreuse is offline
