SailNet Community - View Single Post - DIY - discussion on building a DIY hookah diving compressor
post #100 of Old 05-14-2013
hellosailor
Re: DIY - discussion on building a DIY hookah diving compressor
My limited understanding is that all of the modern "oil-less" compressors are in fact oil free (except possibly manufacturing/machining traces) because they use teflon rings instead of oiled ones. And that is why the small tire-inflator types easily overheat and burn out, from the teflon melting if they are run too long.
Not a question of oil type of quality, just a different piece of equipment that simply does not use oil at all, so it can't contaminate the airflow.
Assuming it has properly cleaned of manufacturing traces during assembly.
hellosailor is offline
