SailNet Community - View Single Post - Splicing 3-strand line to double braid
post #7 of Old 05-15-2013
zz4gta
I don't discuss my member
zz4gta's Avatar
Re: Splicing 3-strand line to double braid
http://www.liros.com/fileadmin/user_...ire_Splice.pdf
I'd do a wire to rope splice but for 2 ropes, I'd double the length of the buries. If you have the means, load the splice to couple thousand lbs and see if it works. This isn't common but it might work. Also choose the largest double braid you can use on your cleats. Ropes that are sized similarly, are easier to splice.
The real answer is to use smaller line. Who wants to coil 1-1/4" line?
Merit 25 # 764 "Audrey"
zz4gta is offline
