SailNet Community - View Single Post - Help pinpointing a leak
post #32 of Old 05-15-2013
johnnyquest37
johnnyquest37's Avatar
Re: Help pinpointing a leak
Your leak is of great interest to me - I have something very similar going on. Just last weekend, I pinpointed a leak coming from inside a limber hole through a floor in much the same place as your leak. I used a snake camera to look in there and found a portion of uncovered glass mat where water is weeping through. Not much water - about 2 gallons accumulate in five days, but it is still disconcerting. I'm guessing at this point that either 1) my hull-keel joint needs rebedding or keel bolts need tightening; or 2) there is hole/crack in the gelcoat below the water line somewhere and this is where the water is migrating to, or 3) there is a leak above the waterline somewhere and this where the water is migrating to.
I do not want to seal over the exposed fiberglass I found in the limber hole for fear that the water will just migrate further along.
Anyway - appreciating this discussion so far.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
