SailNet Community - View Single Post - Coleman stove in the cockpit?
post #13 of Old 05-17-2013
norahs arc
norahs arc's Avatar
Re: Coleman stove in the cockpit?
I have seen several leaks of propane at the connection fitting on portable equipment but only a couple of actual containers leaking.
Tanks belong outside the cabin and in a proper propane locker or attached where any leakage cannot get back into the boat.
Propane lines must have only one connection inside the cabin - to the appliance used. This means each appliance requires a seperate line from the propane tank (or regulator if used).
If you have ever seen a propane explosion you would follow ALL safety procedures without question. ( I was in a building that was destoryed by a propane explosion - a young man not 10' away from me was killed. I still use propane but follow ALL safety requirements plus any other things I think will make it safer for me.)
Used properly, propane is safe on board, and easy to use. I don't care for the smell of diesel or the pumping / priming of some other fuel systems and will continue using propane but always following safe practices. I hope others will Too.
Catalina 27 Aft. galley, dinnet L/O
Update - Sold Norah's Ark Buying A 24'Shark
Saint John NB
Canada
norahs arc is offline
