SailNet Community - View Single Post - Mantus Anchors NEWS: anchor sizing tool
post #15 of Old 05-18-2013
blt2ski
blt2ski's Avatar
Re: Mantus Anchors NEWS: anchor sizing tool
Med,
the article kinda states similar findings issues as you did. In deeper water, the chain wt at shorter scopes could start being an advantage. Shallower water not so much.
Hence the, not sure there is a proper always right way to anchor per say. Just as the weight of the anchor is not always the correct way to look at things too. IE an aluminum fortress when you look at the sq inch of the flukes vs a steel one, the aluminum when set will hold as well as a steel one! Not that I want a fortress style around here........have a heck of a time setting them, vs the other styles. ALong with they do not always reset with tide changes.
I'm also sure a mantus would do great size appropriatly. I do know of one fellow living on ahook in bellingham with a mantus. He complained initially on FB. But with his track record of being ont he hard with a fail anchor system of differenet sorts and reasons........not sure the initial issue he had was the design etc of the anchor! Might be more of a human issue side of things! Not sure what he is hooked up to at the moment.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is online now
