SailNet Community - View Single Post - Prop size for 4-107
post #5 of Old 05-18-2013
bobperry
grumpy old man
Re: Prop size for 4-107
Smoking and overheating are signs of too much prop. You probably se some black oil in your exhaist also, right? Change the prop to an 18 by 12 and you should be fine. If you prefer the performance of a three blade 15 by 10 will work and give you more tip clearance for less vibration. You will be doing your engine a a favor by doing this.
Bob's Blog ....
bobperry is offline
