SailNet Community - View Single Post - Fluxgate compass and the st4000 Wheel "HELP"
post #13 of Old 05-18-2013
Re: Fluxgate compass and the st4000 Wheel "HELP"
I would try and find out if there is something magnetic onboard that is causing your problems. Bring a handheld compass aboard and take readings in different locations (including near but not right next to the boat's compass and fluxgate sensor). You can use a the handheld compass to "hunt" for a source of magnetic interference. If the handheld readings are ok everywhere, then I would suggest that you troubleshoot the problems separately. You can "swing" the main compass yourself and at least get it to be somewhat accurate - Google can help you find specific instructions for your unit. The fluxgate should be tested as per to make sure it is working ok.
tibtib is offline
