SailNet Community - View Single Post - Prop size for 4-107
post #9 of Old 05-18-2013
bobperry
grumpy old man
Re: Prop size for 4-107
I don't know what gear redcution you have but a 16 by 16 three blade sounds like way too much prop. On the V-40's we found a 15 by 10 three blade (as I keep recommending) worked best. I think the reduct ws 2.57 to 1 as I recall. You can go with a two blade prop at the size I have already recommended but I don't think that will "fix" prop walk but it will give you the engine rpms you need and good boat speed. Your excessive prop walk may have to do with all that pitch you now have. What you have now is what we call a "square prop" i.e. diameter and pitch the same and they seldom work well.
Bob's Blog ....
bobperry is offline
