SailNet Community - View Single Post - Prop size for 4-107
post #11 of Old 05-18-2013
PorFin
Seņor Member
PorFin's Avatar
Re: Prop size for 4-107
Originally Posted by pyewackette View Post
Gotcha, thanks for the info I will see what I can do to find a prop matching what you say.
Also, the ratio is 2:51 to 1.
P,
If your current prop is in otherwise good condition, you may want to check with a prop shop and see if they can flatten your pitch down closer to optimal. If the 16" diameter doesn't have clearance issues, then getting it reset will likely be a whole lot less expensive than buying a whole new wheel.
Just a thought...
________
'85 BYB Vagabond 39
PorFin is offline
