SailNet Community - View Single Post - Prop size for 4-107
post #13 of Old 05-18-2013 Thread Starter
pyewackette
Re: Prop size for 4-107
Originally Posted by PorFin View Post
P,
If your current prop is in otherwise good condition, you may want to check with a prop shop and see if they can flatten your pitch down closer to optimal. If the 16" diameter doesn't have clearance issues, then getting it reset will likely be a whole lot less expensive than buying a whole new wheel.
Just a thought...
Thanks for the thought, I'll see what I can do.
pyewackette is offline
