SailNet Community - View Single Post - Fuel tank drain
Thread: Fuel tank drain
post #9 of Old 05-20-2013 Thread Starter
Classic30
Once known as Hartley18
Classic30's Avatar
Dock
Re: Fuel tank drain
Hartles old man ...... what is your fuel filter setup ? Even though the fuel pickup comes out the top of you tank the pickup itself is down the bottom (I'd have thought). With a decent glass bowl fuel filter (or two) any water will collect in the glass bowl and can be easily drained from there. Glass also gives you a good idea as to how much water is in your system.
It's the usual glass bowl arrangement. Hmm.. you might be right, TD.
It's tricky (read: impossible without a mirror on a stick which I don't currently have) to see just how far the pick-up is off the bottom. I'd have thought the pick-up might be a little ways up to make sure you didn't pull stuff into the filter...?
Classic30 is offline
