SailNet Community - View Single Post - Manual water pump priming sucks so much ....
post #3 of Old 05-21-2013
fryewe
fryewe's Avatar
Re: Manual water pump priming sucks so much ....
You have a leak. Fix it. You may have to replace hoses and fittings. If you have transparent hoses you should be able to see the water in the hose at the level it returns to when prime is lost. The leak is likely to be at that point.
fryewe is offline
The Following User Says Thank You to fryewe For This Useful Post:
i_amcdn (05-21-2013)
