SailNet Community - View Single Post - Manual water pump priming sucks so much ....
post #8 of Old 05-21-2013
Ajax_MD
Chastened
Ajax_MD's Avatar
Re: Manual water pump priming sucks so much ....
You have a leak, but it's an air leak.
Air is leaking into the system, probably at the diaphram inside the pump. Hence, you lose prime, but no water leaks out of the system.
Here's what I did: Dismantle the pump and soak the diaphram in a light coating of veg oil. It's safe for humans, and often causes the rubber to swell and moisten, and retain its prime.
1981 Tartan 33 #168
Ajax_MD is offline
