SailNet Community - View Single Post - Making Your Boat Unsinkable
post #10 of Old 05-21-2013
krisscross
krisscross's Avatar
Re: Making Your Boat Unsinkable
Originally Posted by CarpeAquam View Post
I think I could put more than that in without filling any cabin space if I filled the front locker, lined the bottom of other lockers, and used the aft storage under the cockpit. Adding foam insulation to the walls would also add buoyancy (as well as sound/heat).
I'm probably not going to do that, but this doesn't seem unreasonable to me. Am I wrong?
Unless you glass that flotation space over, you can always easily remove the styrofoam or closed cell foam when you realize you need more space than you have left.
Plato
krisscross is offline
The Following User Says Thank You to krisscross For This Useful Post:
CarpeAquam (05-21-2013)
