SailNet Community - View Single Post - My Horror Story
Thread: My Horror Story
post #122 of Old 05-22-2013
MedSailor
Closet Powerboater
MedSailor's Avatar
Re: My Horror Story
Remember: The most accurate time to check your diesel is when the engine is fully warmed up, ie after shutdown. Why? Diesel, like everything else, expands when it warms up. If you (like I used to do) fill the dipstick to the top mark when it's cold, then when it warms up, it expands and you've got too much diesel. That's why many dipsticks say "max" at the top. They mean it.
From what I've been reading, if your diesel is truly running away (which by your smoke definitions it may well be) your problems are almost certainly because there's too much oil in the oil pan.
Now is that too much lubricating oil because you fill it slightly too much?
Is it too much lubricating oil because you have the wrong dipstick (it happens)?
Or, as Bljones suggested, you have blown an internal seal because of the fuel pressure thingy and you have diesel mixed with your oil.
The third one is the easiest to diagnose. Does your oil smell like diesel? No? Good. Now, don't ever run your engine with the pressure pump running again. Bad idea for lots of reasons.
The first and second reasons can be diagnosed by completely emptying your oil pan and measuring what comes out. Measure what goes back in and be sure you have the right dipstick.
MedSailor
PS I was really there (where you are) once. I learned by doing it all myself and by jumping into the deep end. Nobody died, and I didn't break anything of anyone else's that I didn't fix. I turned out alright.... I think.
MedSailor is offline
