SailNet Community - View Single Post - Prop shaft / cutlass bearing overhaul
post #8 of Old 05-22-2013
JimsCAL
JimsCAL's Avatar
Re: Prop shaft / cutlass bearing overhaul
You can make a puller easily from a piece of steel plate. Just drill some holes at the spacing of the coupling bolts. Use a socket from a socket wrench set between the plate and the end of the shaft and then tighten the bolts or threaded rods with nuts, pushing the shaft out of the coupling.
JimsCAL is offline
