SailNet Community - View Single Post - Mantus Anchors NEWS: anchor sizing tool
post #18 of Old 05-22-2013 Thread Starter
Mantus Anchors
Vendor
Mantus Anchors's Avatar
Re: Mantus Anchors NEWS: anchor sizing tool
Originally Posted by Minnewaska View Post
A cruising anchor of 105lbs? My gut says that's either pretty conservative or the Mantua doesn't hold well per lb. I suppose bigger is always better, until you have to retrieve it.
The idea is to envelope, hi winds and poor bottom (loose silty low viscosity bottom), we size the gear so to insure safety with a cruising anchor in 40 knots and poor bottom... We believe our to be the single best all purpose anchor on the market (you will have a guarantied set). In areas with silty bottoms you need a bigger blade surface area to achieve the same needed holding power, so we develop the sizing guide to envelope the worst possible situation as described.
Anchor Purveyor
Mantus Anchors is offline
