SailNet Community - View Single Post - Prop shaft / cutlass bearing overhaul
post #10 of Old 05-23-2013 Thread Starter
SchockT
SchockT's Avatar
Re: Prop shaft / cutlass bearing overhaul
Thanks for the suggestions!
I got my hands on a harmonic balancer puller that should do the trick if I can get a shorter pusher screw for it. I only have 2.5" to work with!
my plan "B" is a short piece of shallow Unistrut with a 3/8 bolt and captive unistrut nut for the pusher.
I didn't have time to work on it today since I had to get the bottom paint on between weather systems!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
