SailNet Community - View Single Post - Reefing set-up for Contessa
post #9 of Old 05-23-2013
Alex W
no longer reading SailNet
Alex W's Avatar
Re: Reefing set-up for Contessa
I only have one reef on my Pearson 28-2. There are padeyes on the boom for two of them however, and I'd have to add a second block to use the second one (or run one of them inside the boom, it has blocks for 3 lines and I'm only using two of them, outhaul and topping lift.
The main on my Catalina 25 was held on with the type of velcro strap that Faster recommends. It works really nicely, but it is a pain to use and might be hard to transfer between sails.
If your boom has no protrusions you could tie (or splice) a bowline into the of your reefing lines and pass that over the boom. That would do the job of the padeye, require no hardware. The new owner of my Catalina 25 is experimenting with that on his reefing line and it seems to work for him.
Alex W is offline
