SailNet Community - View Single Post - Build Fiberglass Rudder
post #3 of Old 05-23-2013
Jeff_H
Moderator
Jeff_H's Avatar
Re: Build Fiberglass Rudder
I would think that it would be easier to carefully grind the wooden rudder and then glass it with epoxy and glass. Plan B would be to make female molds for each half using the wood rudder as a pattern, then glass the halves together. Plan C would be to make a blade from foam core material that you hot knife to shape then sheath with epoxy and glass.
Jeff_H is offline
