SailNet Community - View Single Post - Removing Swing Keel Advice Sought
post #2 of Old 05-24-2013
CalebD
Tartan 27' owner
CalebD's Avatar
Re: Removing Swing Keel Advice Sought
Can you dig a hole under the swing keel? This may allow you to drop it more easily.
400 #'s is not light weight. You are going to need some help lowering and raising this. A spare car jack could easily lift or lower this with additional lines/structures to hold it in place.
As for cleaning out the center board trunk you will have to improvise tools to use. I find that old fashioned hand saws, like a sheet rock saw or cross cut saw will do the trick. Whatever implement(s) you can get up in the slot are what you need to use.
Everybody has one:
CalebD is offline
