SailNet Community - View Single Post - Selector switch or Automatic Relay
post #9 of Old 01-13-2007
sailingdog
Cam-
If you didn't have a 1/2/both four-position switch, then all the ACR would do is combine the banks when the primary bank is being charged, to charge both banks, even if the switch is not in the both position. If you connect a wire to a terminal on it... it will combine the banks if either bank is being charged....which is how I have it setup.
However, without a four-position switch, you can't combine the banks, in the case of dead starting bank.
The ACR has pots that you can set on it to adjust the charging voltage trigger level and the voltage at which the batteries isolate at.
As hellosailor said...there are also terminals on the ACR which will force combining or isolating the banks.
There is a new, smaller type electrical switch that might be a nice choice for you PB. It only has three positions IIRC... Off, start and combine. It is a good deal smaller than a traditional four-position switch.
sailingdog is offline
