SailNet Community - View Single Post - Shore GFCI trips when plugging in boat
post #2 of Old 05-27-2013
n8kraft
Commodore
n8kraft's Avatar
Two separate problems
You have two separate problems, and maybe a common fault. Input power GFCI outlet tripping offline is caused by different current on the hot and neutral wires going to the boat. To rule out a problem with the outlet plug in a regular household 3 prong tool instead of your boat and see if it works.
Since your boat main circuit breaker sometimes trips that indicates an overcurrent condition somewhere in your boat. There may be a short somewhere between hot and ground and neutral that causes the boat breaker and gfci to trip.
Invest in experiences, not things.
Sailing with Nate, Natalie and Sullivan at
n8kraft is offline
