SailNet Community - View Single Post - stays and shrouds too loose?
post #10 of Old 05-28-2013
TropicCat
Senior Pirate
TropicCat's Avatar
Re: stays and shrouds too loose?
Originally Posted by DRFerron View Post
Doesn't it depend on your boat specs? For example, some boats require more mast rake than others to sail efficiently. I don't think the tension of the stays and shrouds on my boat would be the same as a J boat. I could be wrong but I don't think there's one overall rule of thumb that covers every sailboat.
Mast Rake is determined by forestay length, this fella is asking about rig tension.
I've been taught to crank the turnbuckle tight as you can with an open end box wrench (a small one, just 6 or 7" long) while the other hand holds the toggle. When the toggle begins to twist in your hand, that's far enough. No one should have droopy leeward stays in any wind or on any point of sail.
Having said this, rig tuning is an art, not a science.
Tropic Cat
TropicCat is offline
