SailNet Community - View Single Post - Electric Windlass on PSC 34
post #14 of Old 05-29-2013
MarcHall
Re: Electric Windlass on PSC 34
Originally Posted by Ken PSC37 Atlas View Post
Thanks for all the pics and feedback. I'm the new proud owner of an '89 PCS 37, and will be doing the same windlass upgrades as the old one is frozen solid. I like the Tigres and will surely be headed down an electric w/ a manual back up path. 2 questions:
1: Any comments on the wiring? Where did you put the control box. Foot pedal controls, any thoughts on a remote as I will be single handing most of the time?
2. Any issues with the chain stacking and room for chain?
Thanks for your help, Thors pictures have already saved me a ton of time.
Battery Bank on Crazy Fish is under the settee just aft of the bulkhead between the head and the main saloon. 4 T105 fit there after I the shelf installed by PS was removed and a lower one installed.
Cables run there to a switch which is located on the same bulkhead on the far starboard side - back of switch is in the locker behind the head sink. From there they run along the top of the head locker and then above panels in the bunk area in the space created by the hull/deck joint. Cables are 1/0 or larger but I can't remember at the moment.
There is a deck switch mounted a bit aft and a bit to starboard of the windless.
Marc Hall
Crazy Fish - Maintaining, Upgrading and Sailing a Crealock 37
MarcHall is offline
