SailNet Community - View Single Post - Shore GFCI trips when plugging in boat
post #8 of Old 05-31-2013
eherlihy
Learning the HARD way...
eherlihy's Avatar
Re: Shore GFCI trips when plugging in boat
The GFCIs downstream of the fault would not trip.
You may be able to troubleshoot this with a DVM that captures the maximum reading. An O-scope would be even better, but probably not at your disposal. Look for any AC voltage reading between AC ground and neutral at the inverter/charger when it is off, then test again when you turn it on. Run this test again looking for DC voltage.
eherlihy is online now
