SailNet Community - View Single Post - The Saga of the Sad Swinging Keel
post #4 of Old 05-31-2013
CalebD
Tartan 27' owner
CalebD's Avatar
Re: The Saga of the Sad Swinging Keel
However you go about getting that rusty bad old center board out you are going to need an angle grinder tool to grind off the rust and whatever coating remains. They sell heavy duty sanding discs for the 4 1/2" angle grinders that would make an easy job of grinding away the not so attractive outer coating.
Good luck you dragon!!!
Everybody has one:
CalebD is online now
The Following User Says Thank You to CalebD For This Useful Post:
FishDragon (05-31-2013)
