SailNet Community - View Single Post - Sea Fevers Cal 29 Beam of Death
post #11 of Old 06-01-2013 Thread Starter
tommays
tommays's Avatar
Re: Sea Fevers Cal 29 Beam of Death
The Fien is the best tool as it cuts fast neat and the least dust
From the cabin when you look under the settee the center tab by the compression post is the one that will show the issues
In the center of the boats you have three things dripping on the beam
1. They put the ice box drain right there
2. The little drain hole in the head area drips right on the beam
3. The original mast wiring went right through and unsealed hole ,down the compression post so it could also drip on the beam
You should get a good view with a bore scope form the hole in the head area
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
