SailNet Community - View Single Post - Blown outboard prop shaft seal?
post #3 of Old 06-03-2013
ScottyG24
ScottyG24's Avatar
You probably know this already but when you store your outboard for the winter or any period that is might be in less than 32f remove the prop and make sure (by tilting it) that all the residual water gets out of the torpedo/prop shaft area as ice can damage the seal. i doubt your transportation method damaged it. Get the service manual for the engine wether you fix it or have it done by a shop so you know whats involved to R&R it. Good Luck
ScottyG24 is offline
The Following User Says Thank You to ScottyG24 For This Useful Post:
GrahamO (06-03-2013)
