SailNet Community - View Single Post - Blown outboard prop shaft seal?
post #4 of Old 06-03-2013 Thread Starter
GrahamO
GrahamO's Avatar
Re: Blown outboard prop shaft seal?
I probably didn't..... I've never owned an outboard in a cold country before so improper storage may well be the issue - oh well. Didn't have this problem in Australia... (never had to store it). doesn't look like the sort of job I want to tackle so dealer it is.
Originally Posted by ScottyG24 View Post
You probably know this already but when you store your outboard for the winter or any period that is might be in less than 32f remove the prop and make sure (by tilting it) that all the residual water gets out of the torpedo/prop shaft area as ice can damage the seal. i doubt your transportation method damaged it. Get the service manual for the engine wether you fix it or have it done by a shop so you know whats involved to R&R it. Good Luck
Thanks
Graham
Graham and Janaki
Bristol 38.8
GrahamO is offline
