SailNet Community - View Single Post - Blown outboard prop shaft seal?
post #5 of Old 06-03-2013
tommays
tommays's Avatar
Re: Blown outboard prop shaft seal?
Was the unit serviced in the fall ? gear oil change
If not it is the best time as any water would not sit in the gear case over the winter
I would remove the upper gear oil plug to check the level and be sure is in fact gear oil as the four strokes are funny about motor oil when transported laying down
If it is the gearcase there are three seals
Input shaft, output shaft and the shift shaft and if your going to pay someone might as well do it 100% and be done
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
