SailNet Community - View Single Post - Blown outboard prop shaft seal?
post #6 of Old 06-03-2013 Thread Starter
GrahamO
GrahamO's Avatar
Re: Blown outboard prop shaft seal?
Afraid not - I'm more of an electronics guy. I really don't like engines..... It was stuck in the corner and forgotten for the winter. I did flush the cooling system and run the carb dry. I have been belatedly reading the user manual and I am appalled at how delicate these damned things are. Surly someone can design a more robust motor that does not need so much pampering...
Originally Posted by tommays View Post
Was the unit serviced in the fall ? gear oil change
If not it is the best time as any water would not sit in the gear case over the winter
I would remove the upper gear oil plug to check the level and be sure is in fact gear oil as the four strokes are funny about motor oil when transported laying down
If it is the gearcase there are three seals
Input shaft, output shaft and the shift shaft and if your going to pay someone might as well do it 100% and be done
Graham and Janaki
Bristol 38.8
GrahamO is offline
