SailNet Community - View Single Post - Docking with a spring line questions
post #3 of Old 06-03-2013
johnnyquest37
johnnyquest37's Avatar
Re: Docking with a spring line questions
Assuming you are trying to back into your slip:
Come along side one of the piles that will hold the other end of a bow line once you are docked. Not knowing your slip arrangement, let me assume you put your port side to the pile. Attach one end of a line to the pile and the other end to your aftmost port cleat. Center your rudder and saildrive. Put the engine into reverse. The boat should pivot about the pile. You have to slowly ease the line as you back into the slip, and you may have to harden the line and move forward to work the stern in.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
