SailNet Community - View Single Post - Cockpit drain holes
post #2 of Old 06-04-2013
Faster
Re: Cockpit drain holes
Is there space and opportunity to run the scuppers out the back of the cockpit (through the aft wall down low in the corners) towards the transom/ counter rather than straight down to the hull? That would give you more room for through hull valves and possibly keep the whole setup above the static waterline...
Good luck!
Faster is offline
