SailNet Community - View Single Post - prop problems
Thread: prop problems
Old 06-04-2013   #5
Faster
Faster is a jewel in the rough Faster is a jewel in the rough Faster is a jewel in the rough
Re: prop problems
There should be no problem running a 3 blade prop.. it will run much smoother and will have more thrust than the two blade (although more drag under sail) It just needs to be properly pitched. Did you pick the prop up in a bargain bin or have it spec'd for your boat and engine?
There are several prop sizing tools on line, a little time there will give you some basic starting data.
I recommend the Campbell sailor prop as a good compromise between pricey folder/feathering props and the michigan wheels.
These guys are here in BC: West by North Enterprises
Faster is online now   Reply With Quote Share with Facebook
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
