SailNet Community - View Single Post - Power Battery Set up for 27ft sailboat
post #5 of Old 06-04-2013
chef2sail
chef2sail's Avatar
Re: Power Battery Set up for 27ft sailboat
Originally Posted by SlowButSteady View Post
On my Cal 2-27 I have two 6V "golf cart" batteries (Costco) as a "main" bank (about 200Ah capacity) and a 50Ah AGM "wheelchair" battery (Sears Diehard) as a "reserve". The alternator and battery chargers (shore power and solar) are wired to the main bank, with a Yandina battery combiner between the main and reserve banks. Either bank will start the Yanmar 2gm20, no sweat; so when I'm using any battery power I just leave the battery selector switch on the main bank all the time, saving the reserve as a back-up in case the main bank gets drawn down too much or fails for some other reason (neither of which as ever happened).
You have using wet and agm batteries which is not recommended to mix. Ho do you charge the AGM?
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
