SailNet Community - View Single Post - Sailboat Rudder (ROM) Range of Motion
post #2 of Old 06-07-2013
tommays
tommays's Avatar
Re: Sailboat Rudder (ROM) Range of Motion
It depends on the boat my J24 is very happy turning around with in its own length in tight places with the rudder pretty close to 80 degrees
On my Cal 29 the rudder will hit the hull section it is faired into and requires stops so it will NOT be damaged
When doing actual sailing there both fastest when the sails are balanced in a way that the rudder is as close to ZERO movement as possible
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
