SailNet Community - View Single Post - Self Tailing Winches
post #24 of Old 06-08-2013
KeelHaulin
STARBOARD!!
KeelHaulin's Avatar
Re: Self Tailing Winches
For those who say ST winches are slow for racing, I suggest you use the ST head only when cleating off. Lots of people also don't know how to use an ST winch; they put the line over the tailer before pulling the slack up. use the line over the drum only when sheeting the slack; then put it over the ST and trim the sail. It's much faster and reduces wear on the tailer. Also make sure there are at least 3 wraps on the drum because the finger on the tailer can get broken off with too much load on it.
As for the cost; well it's the difference between having to struggle to grind with one hand and tail with the other, or just grinding the winch. much easier so the price of the new units and resale value of the older ones reflect that.
KeelHaulin is offline
