SailNet Community - View Single Post - Passport 42 designed by Stan Huntingford
post #15 of Old 06-10-2013
Goodtoknow
Re: Passport 42 designed by Stan Huntingford
As an engineer and experienced sailor I can tell you that the quality of the Passport 42 is outstanding. Bronze port holes, proper hardware, Burmese Teak interior, stoutly rigged, high volume tankage. The decission depends upon what you will use it for. If you will be going offshore the Passport will get you through when the poop hits the fan. If you don't have a lot of time and plan to sail mainly inland it's overkill and you would be better off buying the performance boat.
Good Luck
Goodtoknow is offline
